jlchristopher
I have the same problem and after 2 months of plugging and unplugging wires I have found my issue. It is with my climate controls. When you pull the radio dash off the top center plug has 3 wires in it. It is right behind the emergency flasher switch on my '13 with 8.4a radio.
I waited until the lights would not turn out and instead of unhooking my battery to reset I went through a lot of fuses. Fuses did not seem to reset it, but I did not pull every fuse. After finding a lot of forums with this issue and reading what they have done that did not work I got curious about the climate module since I could hear my trucks flapper doors opening and closing several minutes after I turned it off.
I cut each of the 3 wires until the red wire (hot wire) turned off the evic lights. Afterwards I wired a switch into it and now use the switch to reset it so I don't have to pull the dash apart. My truck is no longer under warranty so I have been living with that until I missed it the other day and came out to another dead battery.
So as a last ditch effort I bought a new climate control module from the dealership and will install it in a few days when it delivers.
I have a 7:30 am appointment at the dealer tomorrow morning. Will report what they say here.
