Data display
Flryder
Bradenton, Fl
Is there a aftermarket data display that would show me things like trans temp and oil pressure that you reccomend? I have a Tradesman and it does not have this feature from the factory. Do these things plug into the OBD port?
Thanks,
There is apps like Torque Pro(for Android) and Fusion(for iOS) that allow you to read vehicle parameters. You can set up "dashboards" with various gauges to display and even enter custom PIDs to read a lot of specialty parameters. The OBDLink MX+ works with them and can be used with AlfaOBD
I use Torque Pro with my EcoD to read the boost pressure, EGTs, CAC temps, etc. Similar parameters are available on the gassers too.
MADDOG
Living in a Firepit
I use an Edge CTS 2 monitor in my truck. It plugs into the OBD II port and has numerous gauge set up options and gauge type selections.
tron67j
Maryland
That is very cool, and just plug and play? That is going on my truck, I like to know what is going on in the system. Thanks for the information.
Firetruck41
Washington State
2500 Mega Cab Hemi 5.7
Not sure what year your truck is, but I can't get trans temp with Torque Pro.
MADDOG
Living in a Firepit
Mine is a 2017 and my OEM configurable gauge cluster has the trans temp option.
But it is hard to read and the Edge unit has a lot more measurement points to choose from.
Puba08
Long Island
Could you post a pic of this installed? Curious to see how well this blends in to the existing pillar.
Not what it’s designed for but here is how it looks:
rangemaster728
NW Oregon
3.6L
Just sayin’...
The Edge CTS2 is about $370 on Amazon...the A-pillar shroud (if it fits that display) runs about $100.
For around $400 (maybe a bit less) you could upgrade your instrument cluster to a Premium one (7” EVIC) and be done. You can then pick what you want for the programmable portions of the display and it looks MUCH nicer than the 3” EVIC that comes standard with the Tradesman.
That’s what I did with mine; just matched the odometer miles and engine hours.
To be fair, you’ll also need AlfaOBD, an MX/MX+ OBD interface and if your Tradesman is 2018 or newer a security gateway bypass harness, but I already have those. This gear is also useful for adding other things like LED lights, global widows down function, vehicle theft alarm, tow mirrors, etc.
The mechanical portion of the swapout takes all of 5 minutes, plus programming time. Did mine in the driveway 2 weeks ago.
Flryder
Flryder
Bradenton, Fl
My 2012 Tradesman has no EVIC. Pressing mode gives me choices of outside temp, odometer, trip A trip B, and ECO.
MADDOG
Living in a Firepit
Yup...You'll note it's not an exact match but it's so close I really don't notice it. Rather, I'm looking at the screen, not the pod, when I glance over there.
LoadedExpressRam
Gulfport, MS
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Thanks,
Not sure what all your looking for, but my 17 tradesman has a "gauge summary " option on the DIC that shows oil pressure, oil temp, trans temp and coolant temp. Everything I need to know. Seeing volts there also would be good, but not necessary. I can see that on a separate screen if I need to monitor it.
Those A pillar pods are cool though.
MADDOG
Living in a Firepit
Looks pretty good. I wonder if other tuners other than the edge will fit?
I got mine from Edge and it was listed specifically for their unit.
There are lots of other pods out there that fit gauges and monitors of all types.
Raadz
