Another good on to laugh about. For year VP44 injection pump became famous for failures and problem and being expensive to replace. Well people like myself figure out the magic to making a VP44 last a very long time. So if your to replace a VP44 right now its about $950 to $1,100 for a pump through some vendors I know.
Ok so now compare to the CR engine when the injectors start to fail it best to just replace them all since if 1 is failing then the other 5 are close behind. CR injectors are roughly $2,700 to $3,000 for a set of six. I can buy 3 injection pumps for the price of CR injectors.
But at least when a VP44 dies it just leaves you strainded on the highway. When CR injectors go it will wipe out the bottom end of the engine costing you at least a short block.
But in either case if you install a FASS or AirDog fuel system with 2-3 micron filters. Then on the CR's use 200:1 ratio of 2 cycle oil and on the VP44 128:1 ratio of 2 cycle oil they will last a very long time. You got to remember the short comes in both breeds is the filters and the fuel lubricity. Bosch states it should be no greater than 450-460 HFRR. Then think to yourself today's ULSD is 520 HFRR so it not even making the grade with Bosch.
Just some strange tidbit of information...
