DEF Injector
Pilgrimtodd
San Diego
6.7 cummins
I just replaced my 2014 2500 DEF pump and injector. Before driving, I wanted to see if they worked. So I attached the injector to the electrical connection and DEF supply line but didn't bolt it down. Then I turned the vehicle on to see if it squirted DEF and it didn't. Is it supposed to squirt while idling?
Ken226
Washington State
I believe that DEF is only injected into the exhaust stream under certain engine conditions. Basically, when it's up to normal operating temp. At least, that's what ChatGPT says. But, it's wrong almost as often as it's right.
ppine
Forester
Nevada
6.7 liter diesel
NOx are oxides of nitrogen, principally nitrogen oxide and nitrogen dioxide. They are constituents that are emitted under combustion at high temperatures. They contribute to ozone formation.
Therefore, there is probably little or no DEF injected into a cold engine.
Ken226
Washington State
Yes it was.
Sounds like it may be fine then. My understanding of the system is that the pump stays running to keep the system primed, but the injector only flows DEF when the engine is at operating temp, and possibly when some other conditions are met as well.
P
Pilgrimtodd
San Diego
6.7 cummins
Thanks for all the help guys!!!
The only thing I need to know now is whether I need to go to the dealer to have the message cleared?
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
Just a FYI, if you have a volt meter, you can test the resistance. I just had one that went back and i was reading 270 ohms.
Try taking it to a car parts place with the readers and have them reset the code. I think there is a # of cycles before clearing thing
P
Pilgrimtodd
San Diego
6.7 cummins
Thanks, I talked to a diesel mechanic and he said the computer needed to be "flashed" or "re-flashed" and that the dealer could do it cheaper because he would need to purchase the software to do it.
P
Pilgrimtodd
San Diego
6.7 cummins
Ok gentlemen, here is an update with my situation. I ended up taking it to the dealership and they ran a diagnostic and then drove it around and did what they do to clear the message. They said everything was ok now.
Since then, I was wondering if my DEF pump was working right because the fluid level was not budging. I just figured it was too full. I took a trip about an hour both ways pulling my trailer and it finally started to move. Between pulls, driving the truck around town, the warning "DEF System, See Dealer" flashed for about 5 seconds and went away (no codes). I pulled trailer home and nothing since. However, it does seem like the fluid level is not moving again. Prior to any of these problems it seemed like the truck was using up a ton of the stuff. I am worried something is still wrong and that my DEF is getting old. WHAT DO YOU THINK GUYS.
Gr8bawana
6.7 CTD
Even while towing my 5er the DEF gauge moves very slowly.
P
Pilgrimtodd
San Diego
6.7 cummins
I hope that's the case, but mine used to move quickly, not matter what I was doing. Not sure if you read my older posts concerning this whole ordeal. But I ended up replacing the DEF injector and DEF pump myself. So maybe these are acting slower for some reason??? But thanks for the reply, that's good to know.
