Def use
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
would like to see a few posts of your consumption miles per jug mostly looking for non towing miles with long distance runs in one trip 350 miles Thanx
350 mile trips at a time how many empty trips on average to a jug'
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
Not towing, 350 miles will not even move the needle. I've found that a tank of DEF will last me between 7500 and 10k miles not towing. I have a 5th Wheel camper and a 350 mile trip will use about 1/4 tank of DEF.
My normal routine is to get down to 1/4 tank then add a 2.5 gallon jug.
mtnrider
Georgia
DEF usage for 350 miles unloaded you won't even notice. I never measured mine exactly but not towing I probably threw a 2 1/2 gallon jug in every 3000 miles? I never topped it off, just threw in a couple gallons when the low light came on.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Running with a cab over truck camper at 14k GVW and 70-75mph i get about 750 mpg of DEF. Unloaded you will be close to double that.
Sent from my SM-T500 using Tapatalk
leeroy300
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
2020 3 jugs in the first 4000 miles all highway
TWILLIAMS9
As @loveracing1988 stated the 19 and ups use a TON of def. I was very concerned when I was coming from my 17 to my 19 and asked the dealership multiple times. Completely normal according to them and many other owners. I fill up about 3,000 miles without towing.
2021LaramieRBDSL
Pennsylvania
3.0DSL
Getting in on this late but I just bought a 2021 1500 3.0 DSL and Im using about 2 gal per 1000 miles just an empty truck! is there an adjustment to calibrate the DEF pump ?
RamGuy110
2022 Ram 2500
Agreed. Its noticeable more in the 19+ models. Im my 21' I can see the needle move just driving 70 miles unloaded.
JayLeonard
6.7 L Cummins
I topped mine off in CT a few weeks ago and drove back to Florida. Just under 1400 miles. Plus running around locally for a few weeks here in Florida. So maybe 1600 miles or so total.
I used about 3/8 of a tank of DEF. Here's a pic of the gage I just took.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
2.5 gal refill, 20 miles each way to work and home.
135.5 gals of gas
Lurchav8r
