Deleting the 2017 Echo Diesel
Bebop51
Lubbock Tx.
3.0 echo diesel
Seriously considering getting my Echo-Diesel deleted. Any experienced pros or cons out there?
JEFF MANN
Ajo, Arizona
3.0 ECODIESEL
You wil probably have to do it yourself as it's illegal, if a legitimate shop does it & gets caught it could easily destry their business. You may find someone that will do it but it probably won't be a shop. Pros: ECM /TCM gets tuned, possible decrease in fuel consumption,no more regens or DPF, no EGR or EGR cooler, cons: won't be able to trade it in without returning to stock, warranty will be void, & they might not do any recalls if they know it's deleted. I also have a 17, I'm at stage 1 with SFT and have all the parts in the garage to delete but want the EGR recall done first, after that I'll do the delete, right now it seems to want to regen at the most inopportune time.
If you looking to delete the EcoDiesel, check out HD Diesel Supply out of Canada. The EPA has been going after stateside tuners like crazy, going north of the boarder may provide longer term support.
I wouldn't recommend SFT either as there's been some lack of support for multiple reported problems, all the while they'll tell the customer that they've never heard of anyone reporting the problem and blame the problem on the truck. The EPA will probably catch with SFT sooner than later and they resell tunes done by optimal remap.
JEFF MANN
Ajo, Arizona
3.0 ECODIESEL
SFT has been nothing but great with me, I had an issue early on & it was taken care of quickly.
B
Bebop51
Lubbock Tx.
3.0 echo diesel
I am not sure what the SFT stands for. I found a place that will do the delete but they mentioned some possible issues but never explained. They did say no significant increase in mileage would be obtained. They said an increase of 30-40% HP would be obtained. I am mostly after better mileage and less issues with emissions equipment down the road. I am at 128,000 now, so far no issues and love the truck.
JEFF MANN
Ajo, Arizona
3.0 ECODIESEL
SFT = SOFAKINGTUNED. SFT also includes both stage 1 & 2 on the handheld.
sirdumpsalot
Anchorage
I did some research on this recently and just went with HD Diesel Supply. GDE tune doesn't delete the EGR at all anymore but from what I can tell the HD Diesel Supply tune is basically the GDE one from before the EPA crackdown. It also requires removing the SCR, DPF and DEF.
sirdumpsalot
Anchorage
Also their customer service is great, they are very friendly and helpful over the phone and they are happy to answer whatever questions you may have.
sirdumpsalot
Anchorage
Ended up changing my mind, decided it wasn't worth risking doing something illegal and getting caught.
