Diablo sucks it...
VolsRam
Franklin, TN
HEMI 5.7
Did that not make sense haha? When I do little 0-60 and 1/4 mile runs my tires always squal. And the more power I add, the more my tires would spin. So when I watch YouTube videos of trucks at the drag strip getting times, I watch them do a burn out, pull to the line, and run a 13-14 second 1/4 mile without spinning the rear tires. I'm just curious how to do that haha
TylerB
FL
They have a "water box" to assist in the burnout, plus you're usually power braking the burnout which you're not doing that on a launch. Plus the track is much stickier than the street.
Lhemi
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
Ok how do I get this fan blade off, I know it's left handed threads but how do I keep it from turning?
TylerB
FL
You need to make yourself one of these or something similar to fit into two holes of the fan's hub.
I used 2" wide x 3/16" thick (1/8" thick would work too)flat steel about 24" long, two 2-1/2" long 5/16" grade 8 bolts and nuts. Some people have stuck a screwdriver thru the holes and "locked" in place to the cast aluminum timing cover, but I don't like the idea of cracking it.
Lhemi
Lhemi
OKC OK
I did that just sucks! I know it's been a minute since I was in the gym but that sucked!
Lhemi
Lhemi
OKC OK
Now what do I need to change in the tuner?
TylerB
FL
Good! Now set both low MPH fan on temps to 189 and the high MPH fan on temp to 194.
Lhemi
Lhemi
OKC OK
Ok I changed the AC fan to on at 189.7
Lhemi
Lhemi
OKC OK
I've only got AC cooling fan on and AC cooling fan off
Lhemi
Lhemi
OKC OK
I found it
Lhemi
Lhemi
OKC OK
Ok that's set, do I need to go back and unset the ac cooling fan?
popcenator
Omaha, NE
You have an efan or the stock clutch fan?
on the move..
Lhemi
Lhemi
OKC OK
E fan
Lhemi
Lhemi
OKC OK
13's
Here I come
Jmhm17
Massachusetts
5.7L HEMI
This thread is cool.. Ill keep checking back on this. Your doing the same mods I want to do. I see the Efan gave you some power back. Cant wait to here how your HF tune goes.. if its super positive I may beg the Wife to buy a DS next :)
Lhemi
Lhemi
OKC OK
The E-Fan wasn't as easy as I thought it was going to be. You deffenitly want that flat bar with 2 bolts threw it to hold the pully while you try to turn that big left handed nut between the clutch fan and the block. 2 people would have helped a lot.
My hose was going to rub a hole on the new fan at the tip of one of the points on the shroud so I wrapped it in exhaust wrap.
