Did I brick my truck?
TEXAS
Tried to the PCM reset on my truck but now it won't even start. Did this by pulling fuse J18 PCM trans range. Have a red light blinking under the speedo, check the battery voltage sitting at 12.45. Can anybody help? Thanks.
shane1981
millington tn
Pull the battery cables for a few mins then try it
tuned by Jay Greene
stimpy433
IOWA
Did you try unhooking the negative battery cable for 10-15 minutes to see if that resets everything???
admiralforever
TEXAS
Tried removing the cables of the battery terminals, it did not work.
huntergreen
Marine Corps Navy Badge
that will do it!
Kmiko
