Differential fluid change interval
Tangent
Montgomery, TX
3.6 Pentastar
I'm having a hard time finding the differential fluid change interval in my owners manual.
I have a 20161500 V6 regular cab 2WD.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I don’t know why it would really be any different from my 2018 hemi but my manual says to inspect every 30,000 or 3 years or to change at that interval if the vehicle is used for off-roading, fleet, taxi, towing; yada, yada, yada.
Burla
2010 Hemi Reg Cab 4x4
Ir is a real easy item to change, redline will give you a good interval but you need a pump tp put it in, amsoil severe gear has a bag easy to put in if you can get it. Double check manual to see the weight, the 5.7 is 75w140 for the rear, 75w90 for front if you have one. Get that mopar out and put back either of those two, even me makes good fluids for diffs.
If you get redline this is the correct fluid, nick gotexhaust sells it cheaper then anyone. Doesn't matter if you have limited slip or not, that is the oil.
