DIY: 2013-2014 OEM Steering Wheel Audio Control Install
Randomized
Canada
Thanks guys, I have another question. I was looking not up the kit on the website and this note came up and I have no idea the difference between a ds and dt.
VEHICLE NOTES: For Ram 1500, fits DS only. Does not fit Ram 1500 DT.”
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
4th Gen 2013-2018 Ram 1500's (& 2019 Classic) are designated as a 'DS' sales code.
5th Gen 2019/2020 Ram 1500's (New body style) are designated as 'DT' sales code.
Sounds like you'll be fine but you can send a message to AllmoparParts.com and he will get to a link/confirm what you need or post the link here and one of us can confirm.
M² Mods.
Mpgrimm2
SC
5.7L
kp4243
NC
The stock clock spring turns each way 2-1/4 turns. Very LIGHTLY turn it one way until it stops or basically until you feel pressure. As long as you can feel the spring pressure the spring is still good. Turn it it back to the arrow then count 2 exact turn until the arrows are lined up and the clock spring will be centered.
Mpgrimm2
SC
5.7L
Those links work fine for me. One black, one brown.
Thanks for taking a look.
The single link in the op for the steering wheel kit (black one) comes up as 404 error at AllmoparParts.com 's site. It should ideally be replaced with the 2 working links for the black and brown ones I quoted from AMP's vendor page ...
DIY: 2013+ OEM Steering Wheel Audio Control Install
I installed the OEM audio controls, this is a write-up of how I did it.
This will work for all factory radios.
The parts needed:
Left switch 56046099AD
Right switch 56046098AD
Wheel harness 68163713AB
Black back cover 1YH75DX9AC
allmoparparts.com has a kit.
Ram 1500 Steering Wheel Audio Control Upgrade (Part No: RAMAUDWHLKIT)
Here is a video of the airbag spring removal.
M² Mods.
GordDavey
Toronto, Ontario
Another option that I used. When we installed a used clock spring. I went into AlfaOBD and in the SCCM SSCM? Module And you can display the status info you can see the steering wheel degree info. Then set Alfa to automatic updates every 15 seconds or so and turn the clock spring just a bit and you’ll see the steering angle change. That way you will be able to determine which way you should be rotating it. And then you just turn it until it reads around 0. As long as it is within + or - 15 degrees of zero the truck will accept it and not throw an incorrect steering position error.
It kept me from turning it the wrong way and damaging the spring.
kegger
3.6 pentastar
Awesome write up guys!
Question I have is this. I bought a harness and buttons on eBay. Pulled the steering wheel off and too it apart. Well the harness that I have had a pair of wires (brow/white) going to the four white round parts. Well this new harness doesn't have that. It has the wiring to both the front controls and the two buttons and the one main white wire at the top....just not the brown and white wire. Can I "splice" or repin the new one for the proper wires?
kegger
3.6 pentastar
Two harnesses. My old one on the right.
kegger
3.6 pentastar
Ok so I tore the old harness apart and found that the seller must have cut that extra wire off for whatever reason. I've spliced and soldered the old one to that new and hope it works!
kegger
3.6 pentastar
Ok new issue. Cruise control stopped working as well as the gear up and down. Can I assume that it's the older harness? It looks like it came from a 2010 and I'm putting it in a 2016.
Mpgrimm2
SC
5.7L
You need to get the correct harness as listed in the OP, it's only $25 dollars new (Here:
68163713AC)
. The 09-12 trucks are different than the 13-18 trucks. I'd hate to see something catastrophic happen with an airbag deployment, cruise control malfunction, etc.
kegger
3.6 pentastar
Thanks Mpgrimm2 that's what I assumed. The switches are compatible though correct?
Mpgrimm2
SC
5.7L
Don't know, probably not. They aren't simple switches since they send out multiplexed/bussed communication messages over the LIN Bus (Local Info. Network) to the BCM. If they aren't the correct PN as listed in the OP, I wouldn't count on it working.
kegger
3.6 pentastar
Crap lol well if that's the case I'll only need to replace the one switch on the right side. Rock auto sent one with the back cover!
SimmZ
Quebec, CAN
Pentastar 3.6
I just bought a brand new RAM 1500 Classic (DS) 2019 and although I got the uConnect 8.4c system and several technology options, I was shocked to find that I don't have the audio controls on the steering wheel. I am mostly shocked that FCA voluntarily omit a part that may cost them $ 10 during the assembly process! It's a shame! My 19K$ base model Grand Caravan back in 2014 had the steering wheel controls from factory as base equipment...
Anyway, good to know that it's only a matter of a 45$ kit of a bezel, buttons and a small harness. However I am not equipped myself with any puller and don't really have the time to mess with that. So if I request my dealer to install the 3 parts for me, how much time do you think a professional mechanics with appropriate tools may took to perform this install?
Mpgrimm2
SC
5.7L
@SimmZ
They should be able to do it in 30 mins to an hour. No programming is required.
M² Mods.
Marty424
