DIY Investigation of water in the cab
There are many posts about water in the cab, almost all of them turn out to be the 3rd brake light gasket.
I found a video about one guys attempt to find the root cause of his water leak.
He took everything out of the back of the cab.
Even if you don't have a leak, you may wonder just what is in back of the rear seat, he filmed everything, you can even see the wiring
An interesting video about making your own 3rd brake seal
Ram's way of fixing it, sucks
you would just be delaying a real fix, it may work until a bulb goes out
checking the air vents between the cab & the bed
Rear Slider Window track overflows inside cab
This guy removes his track within a track, to discovery why his cab gets wet inside
phorrestphire
