DIY IPA wipedown knowledge
Discussion in 'Detailing' started by ramportin1, Nov 9, 2018.
  1. chrisbh17
    chrisbh17 Senior Member
    3,588
    3,404
    Oct 12, 2017
    Ram Year:
    Engine:
    Ultra is too expensive for my blood plus I don't think I can buy it myself anyway?
    Sent from my Nexus 6P using Tapatalk
    McBroom likes this.
  2. ramportin1
    ramportin1 Sickest member here
    32
    3,177
    1,979
    Jun 28, 2017
    Oregon
    Ram Year:
    Engine:
    This is actually from autogeek though I did find a bit of chat about it, this was by far the most in depth and backed by chemistry
    McBroom and Pull Ya like this.
  3. McBroom
    McBroom U.S.Marine Veteran Retired 88-2000 Military
    48
    3,419
    3,146
    May 25, 2017
    Denison Tx
    Ram Year:
    Engine:
    Hemi 6.4L
    Why can’t you buy it yourself?
    More info please.
    Blue Streak Pearl off-road
  4. ramportin1
    32
    3,177
    1,979
    Jun 28, 2017
    Oregon
    Ram Year:
    Engine:
    I dont know about that specific product but there are many coatings that a regular consumer can not purchase themselves, professional level ceramics and what not
  5. Joshwaa
    Joshwaa Senior Member
    778
    191
    Feb 14, 2011
    Lake Worth, FL
    Ram Year:
    2016 CC 4x4 Laramie AirRide
    Engine:
    GTechniq will not sell ultra to a consumer. You have to go through their training course to be able to get it. Main reason is if you mess up bad during application with ultra you need to sand it off. When applied it is rated at 10h hardness. It can withstand between 2-13pH.
    From their website:
    If you miss removing residue and it cures fully you will need to carefully wet sand the affected panel, repolish and then reapply Crystal Serum Ultra. Unlike C1 Crystal Lacquer or EXO you cannot remove the fully cured film with a cutting compound.
    chrisbh17 and McBroom like this.
  6. McBroom
    48
    3,419
    3,146
    May 25, 2017
    Denison Tx
    Ram Year:
    Engine:
    Hemi 6.4L
    That’s way the fuck above my skill level.
  7. chrisbh17
    3,588
    3,404
    Oct 12, 2017
    Ram Year:
    Engine:
    This.
    And that is why I wanted to go with the "Light" version anyway. On a white truck I found it a huge PITA to not only find swirls to correct (they are there but the color is so bright its sometimes hard to stare at it and find them) but its also hard to tell if/when the coating is flashed and if there are any high spots left.
  8. Joshwaa
    778
    191
    Feb 14, 2011
    Lake Worth, FL
    Ram Year:
    Engine:
    Yea white is a hard color to deal with. I found that if you point a good LED flashlight at a 45deg vertical angle and look at it from a 45deg horizontal angle is about the easiest way to see swirls and marring. However trying to apply a coating this way is not feasible. To do a coating on a white vehicle you really need a garage with a bunch of lights (ceiling and walls).
  9. chrisbh17
    3,588
    3,404
    Oct 12, 2017
    Ram Year:
    Engine:
    Yep, except my ram doesn't fit inside my garage lol
    The gloss coat came out good. I found it easiest to apply around dusk where there was some natural light but the sun was down.
    Joshwaa likes this.
Share This Page
