Iceskyline25
This is pretty simple DIY but I figure I would make one in case anyone was having trouble finding it or replacing it.
Time: 10-15min
Cost: $6-$15 depending on where you buy it
Tools:
Flat Head Screw Driver
Needle Nose Pliers
Step 1: Remove Air filter box to have better access to the PCV valve
Step 2: remove the hose attached to it by just pulling on it towards the firewall if it's pretty stuck on there you can use the screw driver to loosen it up.
Step 3: push the PCV valve in and turn it counter clock wise. Then pull
Step 4: Repeat all the steps backwards and your done.
Hope this help someone
Time: 10-15min
Tools:
Needle Nose Pliers
