Jebb
- Joined
- Aug 22, 2017
- Posts
- 127
- Reaction score
- 65
- Ram Year
- 2017
- Engine
- Hemi 5.7
I have seen several YouTube videos lately showing a 1500 4x4 stuck in the snow with one front wheel spinning, one back wheel spinning and the other two wheels doing nothing, i.e., the classic "open differential" 4x4 scenario.
I don't understand this. According to my owner's manual, my 4th gen truck (and I thought all 4th gen 1500s) has "active LSD" that uses the ABS system to apply braking force to the spinning wheel(s) thereby shifting the load to the wheel(s) with traction. AFAIK, the once very common clutch pack LSD offered by the factory appears to have been eliminated in favor of this "active LSD" system, at least on the 1500s.
I have been in slippery situations where I had one back tire in the mud and the other on dry ground. At least in my case, when the "mud" wheel started spinning the other one started pulling - as I expected. At least in my truck, "active LSD" seems to work. (And I am certain my truck does not have a mechanical LSD).
I also understand from the owner's manual that disengaging "Traction Control" does NOT turn off the active LSD - it only turns off throttle modulation. So, AFAIK, these trucks should not be spinning opposite wheels like this.
So what's going on in these videos? Did the YouTubers' pull their ABS fuses before making these videos - or does the "active LSD" system not always work?
