Do all newer Rams have Autopark?
Truck Fun
Missouri
2021 Classic
Do all newer Rams have Autopark? Is there a way to know if my truck does without trying to create the situations that engage it? Not something I want to start experimenting with doing. Can't find anything in the manual. Thanks.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
My 16 does not but I do believe all the new trucks do.
dav8388
Summerville, SC
In limbo between trucks
3.6 pentastar
My 17 does. Found out it had it by moving the truck when the door wasn't fully closed.
misfit77
I heard of an option for auto park.
It's called the ******* button. You press it and it back-in parks for you.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
My 17 doesn't but is supposed too apparently. I keep getting notices about a recall for it, the cruise control issue and the tailgate issue some are experiencing. Wish they didn't have to include the autopark feature but will eventually get the recalls taken care of.
Can Water Geo
Dawson Creek, BC, Canada
Seems like a pretty simple workaround, if you are backing up to a trailer take 2 seconds to dummy up the seatbelt if auto park is active.
Punishher7
This is only on 1500s right?
LouieBlues
Senior Moment
North Jawga
2017 Sport 4x4 SCSB
I found out the hard way that I had it, my door wasn't completely shut.
I thought I broke it and had to call the dealer... I almost pinched a hole in my shorts.
David H
USA RET
Minneapolis
From my 17 manual...
If the vehicle is not in PARK and the driver turns off the
engine, the vehicle may AutoPark.
AutoPark will engage when all of these conditions are met:
• Vehicle is equipped with a rotary shifter and an 8-speed
transmission
• Vehicle is not in PARK
• Vehicle Speed is 1.2 MPH (1.9 km/h) or less
• Ignition switched from RUN to ACC
NOTE: For Keyless Go equipped vehicles, The engine will
turn off and the ignition switch will change to ACC mode.
After 30 minutes the ignition switches to OFF automatically,
unless the driver turns the ignition switch OFF.
If the vehicle is not in PARK and the driver exits the
vehicle with the engine running, the vehicle may AutoPark.
transmission
• Vehicle speed is 1.2 MPH (1.9 km/h) or less
• Driver’s seat belt is unbuckled
• Driver’s door is ajar
• Brake Pedal is not depressed
The MESSAGE “ AutoPark Engaged Shift to P then Shift
to Gear” will display in the instrument cluster.
