Does 2018 Promaster 3.6 have a TIPM?
Slcjim
Taylorsville, UT
I have the service manual and it mentions a TIPM but under the fuse block cover is the Power Dist. center. Next to it the metal ECM. I can’t find a TIPM. Queries say there should be one. What gives?
Burla
2010 Hemi Reg Cab 4x4
You fuse box is the TIPM, you plug relays into TIPM, if you can find relays you found TIPM.
TIPM stands for Totally Integrated Power Module, it can also be called a Power Distribution Module. Dodge/Ram probably stopped using the TIPM moniker due in part to the somewhat know problem of them failing in the Gen3 trucks
Steve58
