Door ajar signal when using turn signals
Dick1
Central Michigan
5.9 Diesel
System thinks a door is open,sometimes ramdomly but almost every time a turn signal is used,some times can cancel the ajar alarm by signaling the other direction.its an o3 3500 w/diesel,anybody have any suggestions?
D
Dick1
Central Michigan
5.9 Diesel
wish it was that easy. dealer told me to check the connections under the fuses,did that,they were good and clean,made no diff.
D
Dick1
Central Michigan
5.9 Diesel
Ever find the problem,have the same issue,not the door switches,cut all the wires in doors and same.Ajar lite comes on a lot when the turn signal switch is used,some times can turn it off by tapping turn signal switch,
