door hinge grease
Average_gatsby45
Cummins diesel.
i have a little groan on my driver door, what kind of grease are we supposed to run?
Razzman
Southern Arizona
2020 Limited CCSB
I use a dry silicon spray lube and it works well without attracting dirt and such.
jasonw
South Dakota
3.0L Hurricane HO
PB Blaster or Liquid Wrench. One short blast and a few door open/closes to work it in. It lasts about a year before I have to repeat the 5 minute procedure.
Mike Flea
US ARMY VETERAN
Streamwood, IL
I use a spray white lithium grease. It has a thin nozzle tube (like what you get with WD-40), so it can be sprayed directly into the hinge
WD-40 is a water displacer. The amount of oil that lubricates is less than 25% of the spray. Here's more info, scroll down to "Function" https://en.wikipedia.org/wiki/WD-40
BWL
Embrace the skeptisism
BC Canada
That's what I use except the CRC brand.
Might try that 3 in 1.. Looks like it might work better.
I use wd40 to clean and get moisture out then fresh grease always worked well for me.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I use AR-15 barrel nut grease it works awesome
aidmyaim
Detroit
V6
White lithium grease clean first with wd-40.
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
Reticle918
