door switch panel
mulutchoker
2004 dodge ram
cummins
2004 2500 ctd all of a sudden both front door panels that hold the switches just came loose.it appears that the housing has spread open.and now the tabs are broke off the panels.is there a good place to get the switch panels,i dont need the swithes.
Davy120
fairchild afb
EBay at about 25 bucks a piece
A modder is never truly done, he is merely delayed!
LS5DodgeRam
South Florida
4.7L v8
I had the same problem, but I used a good weather striping glue and it hasn't moved since and I cleaned up the edges so you don't see the glue.
