Drive Line?
Cowdog
Santa Maria
I have a 2015 Ram 1500 crew cab shortened with two piece drive line. Can it can be converted to a single drive line? Also if you have done it please comment with whatever you feel pertinent.
Just out of curiosity, why switch?
You don't read about the midshift bearing being troublesome.
Cowdog
Cowdog
Santa Maria
When I get on it I feel a vibration from stopped to about 30mph or till it shifts into 3rd. I don’t push and most the time I drive like a old man
Tach_tech
5.7L HEMI
Have you checked your U-joints.
Tach_tech
5.7L HEMI
Did you actually take the 2 piece driveshaft off and move the joints through their full motion. Could also be the steady bearing.
Cowdog
Cowdog
Santa Maria
No I haven’t gone that far but looks like my next step. How do you check the stabilizer bearing
Tach_tech
5.7L HEMI
To check the centre bearing, just make sure there’s no signs of rust coming out, spins freely, the rubber isolator isn’t falling apart.
The u-joints should move freely throughout their range of motion. If they stick/bind or show signs of any rust coming out from the cups, it’s a bad U-joint.
Cowdog
Cowdog
Santa Maria
I figured it out
The truck come lifted but never put the spacer on the center support bearing. Now after adding 1.5 inch spacers it’s perfect
