Driver seat noise?
SD38-2
Indiana
Lately I've been hearing a popping or a clunk in the drivers seat in my regular cab 14 ram 1500 express. It sound like it's either coming front the back of the seat bottom or the back rest of the seat. The seat isn't powered. I can't seem to find anything loose either. I've been thinking of taking my truck to the dealer since it has a few thousand miles left on the bumper to bumper warranty. Anyone else have this issue.
RamCares
n/a
n/a
Hey SD38-2,
If you need any help with the dealership, let me know. Happy to follow up or make an appointment if needed!
Kori
Ram Social Care Specialist
SD38-2
SD38-2
Indiana
Hey SD38-2,
Kori
Kori, thanks! My local dealer is Greiger motors in Valparaiso, that's where I bought the truck too. I plan on taking it in this week, just haven't made an appointment yet.
indebt
I have a similar type of noise. Took the truck to the dealer twice, they didn't hear anything. No longer in warranty but noise is still there. Only hear it when making a turn, but not every time. Unless it gets worse, not much that can be done.
RamCares
n/a
n/a
No problem--if you end up needing any help, just send your VIN in a PM.
Kori
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Just a wild guess have you checked all the seat bolts? All tight ? Could a Spring have broke?Try pushing down on the seat in different sports . It may be a spring that is loose or broke a weld ? Just a guess :) Now the Noise I get from my drivers seat comes usually after TACO's and Burrito's :roflsquared:
If you ever do find out the issue please update us Thanks
SD38-2
SD38-2
Indiana
Seat bolts were all tight, doesn't seem like it's a broken spring. I have an appointment at my local dealer on monday. I'll see what they say. Now I do get the taco noises once in a while in my driver seat, I can pin point them by the smell! I will update after I take the truck in to the dealer.
SD38-2
SD38-2
Indiana
I had an appointment this morning at the dealer, they ended up ordering a new seat adjuster frame. They didn't find anything broken on the frame but they said it was the cause of the popping I've been hearing. They also looked into my radio freezing up while using the satellite radio. They tried updating the radio but it wouldn't fix the problem so under warranty they are replacing the radio and the seat frame.
RamCares
n/a
n/a
Hey SD38-2,
Sounds like your dealership has everything under control, which is great to hear. Please let me know how everything works for you once the repairs are complete.
Kori
SD38-2
SD38-2
Indiana
Hey SD38-2,
Kori
I dropped my truck off Wednesday night, I was given a 2017 1500 ram to drive while they worked on it. I picked up my truck after work Friday and the seat noise is gone and the radio isn't freezing up anymore. I'm very happy with the service depts staff and work.
Branden
California
I had same issue with F150. They greased the mounting surface between the seat and track. Problem solved.
Aaron Gilliam
Las Vegas, Nevada
5.7L
I have the same problem on my ‘12 ram crew cab. It appears it’s a very common problem andnancan of molly chain lube. There’s a complete procedure to fix the issue but another user had his fixed under a TSB.
Vehicle Level Technical Service Bulletins All Technical Service Bulletins Interior - Front Seat Clicking/Squeaking/Creaking Noises Interior - Front Seat Clicking/Squeaking/Creaking NoisesNotesNUMBER: 23-011-09
This is a post from mxkop on dodgetalk.com foot instructions to diy.
GROUP: Body DATE: April 17, 2009 SUBJECT:Creaking, Clicking Or Squeak Sound From SeatOVERVIEW: This bulletin involves applying lube to the rear cross tube for front seats equipped with manual seat tracks. MODELS: 2009 (DS) 1500 Ram Pickup NOTE :This bulletin applies to vehicles with sales codes (JP8 or JRT) and built before March 13, 2009 (MDH 0313XX). SYMPTOM/CONDITION: The seats may make a squeak, clicking or creak sound when: i.Stopping and accelerating ii.Driving around corners iii.Adjusting the seat This may be more noticeable at colder ambient temperatures.DIAGNOSIS: If the customer describes this condition, perform the Repair Procedure. PARTS REQUIRED:NOTE : One can of lubricant can treat more than 10 vehicles. REPAIR PROCEDURE: 1.Open passenger door. 2.Slide passenger seat to full forward position.3.Disengage the 2 plastic J retainers underneath the rear of the seat from the support wire on the seat frame.(Fig. 1). 4.Disengage the plastic J retainer from the back-retainer is sewn into the cover and is a two piece plastic retainer (Fig. 2). 5.Protect floor and surrounding areas from excess lube. 6.Lift the lower section of the seat cover and move aside the foam covering the cross tube to metal bracket joint. a.Spray lube (Sprayon S00202 11 oz. Moly Chain Lube and or equivalent) around the entire cross tube to bracket joint as shown in (Fig. 3). b.Repeat for same joint on other side of seat. 7.Grasp the upper back of the seat being repaired and move side-to-side. If 'subject' noise is still present, repeat 8.Using a marker draw an X on the cross tube part label to acknowledge the seat has been lubricated (Fig. 4). 9.Reattach the two piece black J retainer. 10.Reattach the 2 white plastic J retainers. 11.Repeat Step # 1 through Step # 10 for the driver seat, if also equipped with manual seat.
Mine makes more of a popping sound and I could have sworn it was something in my floorboard storage compartment. But it’s definately not. It’s empty and still clanking. It’s irritating the crap out of me.
Chickamauga, GA
Mine is doing it now, I can feel it, usually when I think I am making a left turn, it's driving me nuts.
warRAMMER
2019 Classic with the same issue here. First time I took it in, they tightened the track bolts. It sounded better for a few weeks but now is worse than ever. I talked with Don Davis and they said the trim guy would ride with me to hear it. I will post results when I get this done.
hunterdan
SE PA
2019 classic
Definitely post up results because my 2019 classic is doing it as well. I removed the front mounting bolts and reinstalled and it went away for a few weeks. But still does it now and then.
RamCares
n/a
n/a
Hello @warRAMMER, let us know if you would like additional assistance alongside your dealer appointment! If interested, send a private message our way.
Hannah
Ram Cares
