Got my driveshaft from @Hemi450hp Moes performance yesterday.
I'm STILL looking for a source for a crossmember notch before I install it.
3/4 lowered
Well ****. I have this one. 2017 Reg Cab 8 spd. So I guess it’s a good idea to replace before it’s too late? Any ideas on what to go with???This is the one that likes to rearrange the undercarriage of your truck..... and not in a good way.:/
I have the 3.92’s. Is it something I really need to be concerned about if I’m not going on the strip?
85 mph is a normal speed on loop 101 in Arizona. I run 4.56 gears and haven't had any problems with speed and the driveshaft. Not saying it doesn't happen but it hasn't happened yet.![]()
Something just came to mind,
Is it possible that the
Ram regular cab shortbox trucks with the 8 speed
are using the type of driveshaft that
Chevy used back in the '40s & early '50s
Back then they called them Closed Drive Shafts
Other note. I have to drive approx 300 miles to work on Tuesday so I will not have time to do the swap before going. I have already changed my tires to 305/50/20’s so they’re an inch (shorter) less tall. So what would you say a safe speed would be considering this?
If you're gonna comment,at least do some research and read the guys post Red. He has a regular cab shortbox,you have a crewcab or cab cab 4X4 if i remember right. You're truck uses a totally differant driveshaft. The only trucks with driveshaft issues are the little regular cab shortbox trucks with the 8 speed,as they use an oddball driveshaft,totally differant from any other Ram 1500. The driveshaft on them bolts to the transmission and to the rear end,and the slip yoke is in the driveshaft itself and is unsupported. Once the trucks get some driveshaft rpm ,like when you're going down the road at 80+ mph the driveshaft starts to turn itself into a skipping rope.A year or 2 back FCA couldn't keep up with replacing the driveshafts on the little 8 speed RCSB's,and there was a world wide shortage on driveshafts for those trucks,they were back ordered everywhere. Regular cab shortbox 4X4's with the 8 speed are safe as they still use a normal driveshaft with a slip yoke into the transfer case.The little 2 wheel drive regular cab shortbox hemi trucks with the 8 speed and 3.92 gears are notrious for blowing the driveshaft right out from under the truck,and breaking the transmission's case when they do. The 3.21 geared trucks are a safer bet,as they don't have the same driveshaft rpm as the 3.92 trucks have at 80+ mph.
I'm read it all.
I'm just more on the side of Defcon 5. He'll be fine if he drives it reasonable. Some folks smash Defcon 1 like there is no tomorrow. That's all.
Don't drive like an idiot till you upgrade the shaft and get yourself a driveshaft loop while your in there.
