redram65
I used OBDGenie in order to turn on DRLs (before I knew about AlfaOBD), this uses the turn signals as DRLs, and causes the DRL on the respective side to drop out when a turn signal is used.
What I'd like to do is have DRLs work just like turning on running lights does, marker lights essentially.
Playing around with AlfaOBD, the choices for DRLs are Optional (which OBDGenie uses), Canadian DRLs and a bunch of European DRLs. The DRL lamp location dropdown shows high breams, low beams, turn signals, fog lights etc, but nothing for marker lights.
Anyway, just wondering if anyone here has played around with the DRLs in AlfaOBD and knows what all the choices are?
Tnanks
Tnanks
