Bluegill1
OK, I picked up a 2014 2500 Tradesman with RamBoxes. I'd like to either do a spray in liner or preferably a drop in bedliner, previous owner had a fifth wheel, the mounting holes and outline kinda make it obvious.
My question is,
1. If I do the drop in, I assume it'll be the "under bed rail" version?
Also, I assume the RamBox rail system has to be removed to get the drop in behind the rail system?
Drop in the liner then re-install the rail system.
I'd also like to get some snap-in caps to fill the Fifth wheel mounting holes, four of the holes are pretty big, the others are probably small enough to be left alone.
Reason for the dropin -vs- the spray in is only because of cost, dropp-in is like $330. I'm assuming spray-on will be in the 6-700 range.
Anything I'm missing? anything I need to know?
Thank you,
David
My question is,
Thank you,
David
