Dropping a Quad Cab....
3rdStrikePerformance
Sikeston, MO
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Duane, you might mention to the truck's owner that folks often weld the flip kit spring pads to the axle to keep them from rotating.
OklaHemi
new age hemi
wow that looks sweet
Trupiano
Registered User
6.7L CTD
Looks awesome Duane! Great job!
Haha I was just gonna say that! Might wanna wait till he cuts the frame though, since they'll prolly be welding anyway.
Trupiano
Registered User
6.7L CTD
Yeah but talk to Moes, he has a pic of a guy that had the McGaughy's flip kit installed without welding the spring perch, and the aftermath of a couple burnouts. It's not pretty! I recommend welding them!
Redtruck-VA
Virginia
Not really neccessary with the McGaughys kit, as their rocker extends up into the old leaf spring perch.
The OEM perch was designed to hold while being clamped to the spring, and as you mentioned, when flipped the new perch is now mounted under the unsupported OEM perch and has the protential to allow the axle to spin. It works great to get the pinion angle correct, but is not as strong as it should be. Most of us have the new perch spot welded to the axle to play it safe. Individual call....
Redtruck-VA
Virginia
Duane, I would definitely encourage him to have it done. Actually if presented with an opportunity to spot weld it without incurring a lot of additional cost I would go ahead and get it done. The liability and embarrassment of having it come back on “your” install wouldn’t be worth it to me personally.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Will third the idea of atleast a good spot weld. There have been a few pics floating around the forums over the years of guys punching it and the axel twist and wreck about everything under the bed.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
that ram looks so much better, i need to find a place to do my c-notch install as well
Sikeston, MO
It was recommended to him. It will be up to him if he does it or not. It has a very anemic 4,7L in it right now though, and I told him to be very gentle with it for now, not to go over 55, and not hit any bumps hard, as we still have to align it, put the c-notch in it, and check everything over again. I always try to get them to bring the vehicle back after it has a couple hundred miles on it to check the suspension fasteners, as driving them sometimes makes them settle different than when they were installed, and I want to make sure it is completely safe. I will probably just have the guy that is cutting the c-notch throw a bead on the perchs too.
noraa73
