Dual battery + engine sputter
Cbuts05
Hey guys looking to add a second battery in my 08 1500. 5.7 for car audio.
Been doing some reading and seems to I need switch to cai? And get a tray from a 2500 . Can someone verify this .
Also at low rpm I get a flutter as I accel, what could this be 02 sensor ?
Thanks !
Ajwalk2008
Springfield, il
I've got a car audio battery under my center counsel in my truck. How many watts are you running
C
Cbuts05
I'd rather put it under the hood.
Running 1500w rms amp for subs
500w rms amp for speakers.
But I want to upgrade eventually .
Ajwalk2008
Springfield, il
Look at Xs power for a good battery. You may have to make a custom cai but idk. Are you running a bigger alt as well?
C
Cbuts05
No bigger alt right now, I've heard mine is fine for two batteries .
And the sputter/ flutter is hard to explain..if I'm doing 50 n let off the gas n coast, then accel again, I hear it until I accel harder
MTLHEMI
HEMI 5.7
Maybe an exhaust leak. Mine does something like that at the same speed . Gasket at front pipe is leaking apparently
Sent from my SM-A500W using Tapatalk
C
Cbuts05
Is this easy to change ? Price of part ? How to tell if it's the issue ?
Thanks dude !
usaf2006
Augusta, GA
Could be your egr valve. Pretty sure I can hear mine under light throttle thru town.
Ajwalk2008
Springfield, il
Was just wondering because we have a 160 amp alt option for our trucks
C
Cbuts05
:favorites13:
Yeah 136-160 isn't going to help me a whole lot,when I upgrade the alt I'll be going to 240+
MTLHEMI
HEMI 5.7
Could be just as simple as changing a 10 dollar gasket. Run the truck and climb under. See if you hear an exhust leak. A quick fix to see if it was the problem is to use a bit of muffler cement to temporary seal the area maybe.
C
Cbuts05
Thanks dude. Does plugging the muffler help decide ?
MTLHEMI
HEMI 5.7
No need to plug the muffler at all. Just fill the leaks with muffler cement for a quick fix. Won't last long but at least you'll know where the exhaust leak is coming from.
R/T_Fire
Pleasant Grove
Not sure if you have figured out your battery issue but there is alot out there that you can borrow from the jeep 4x world using optima sealed batteries. you can mount under on the frame where there is room. Look into balistic fab or rustys offroad. ORU may make some stuff too.
Or something like this down under the cab or bed. You can always put it on the passenger side of the frame close to the amp in the cab.
Optima Single Battery Box - RuffStuff Specialties
C
Cbuts05
Thanks I bought a second battery tray from a 2500 to replace my air box
