LTDMan
- Oct 4, 2014
- 73
- 18
- Location
- Monroe, NC
- 2007
- 4.7 Magnum V8
I'm installing a dual electric fan setup into my 07 Ram. Everything is installed, and I'm at the point of wiring up the relays to a switched 12V source. I'm trying to make sure I tap into the right wire here, so it doesn't interfere with the proper operation of anything, or end up damaging the TIPM.
Does anyone know what the best 12V ignition switched wire to tap into under the hood would be? Or will I have to run the wire inside the cab? Obviously I can probe the hundreds of wires one by one, but I'm hoping someone here has done this before and can save me the trouble. Thank You guys in advance.
