Anyone have an E-fan just stop working? I noticed the temp go up a couple degrees from where it normally sits, (189) the other day at an idle. Light turned green and I watched the temp go back down as I gained speed. I have been out of town since this happened. Got back and figured I would check everything out. Coolant level and what not. Started up the truck with the hood open to see if the E-Fan would activate when it needed to. Nope. Never came on. I shut the truck down when it hit 201. I checked all the wiring and connections, and everything is good. I didn't check to see if the fan will actually spin, but i will when i get home tomorrow. I never have had any issues with them on the older model vehicles i built, so I'm wondering what the heck the issue could be.
Not sure how or why that would happen, but its worth a shot.
