E-Fan Questions
redram2007
Colorado Springs (Ft Carson)
I currently have the flexalite 183 installed and i dont much care for the temp sensor probe that you push through the radiator fins. I found a 38mm (1 1/2") adapter to install in the upper radiator hose by splicing the hose. It has a 1/8" NPT threads for a temp sensor but most sensors i have found only have 1 post for the wires. The probe that i have now has 2 wires that go to the VSC. Maybe hook both wires to the sensor? I have check for continuity and there is no resistance in the 2 wires to the probe. Has anyone done this or have any suggestions on how to wire it up to the flexalite VSC?
38mm Silver Universal Aluminum Radiator Water Temperature Adapter Sensor Gauge | eBay
Old Dog Street Rods
Or should i look at something like this?
Xenocron Tuning Solutions: AEM Fluid Temp Sensor Kit 1/8 NPT
HemiBabe
DFW
Bump for ya, hopefully someone will chime in
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Are you still gonna have the fan trigger by the temp sensor or run a manual toggle and just have a more accurate reading?
redram2007
redram2007
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
That is the reason why I will always buy Flexalite for my fans. You wont find better customer service when it comes to warranty work or tech support.
redram2007
redram2007
Agreed. Their customer service rocks. If you were to buy a Taurus fan or something like it you dont get service like that.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The Taurus fans are just good cheap fans that move a ton of CFM. Kinda turns into easy install run Flexalite, move involved install with fab work is the Taurus.
