e-Torque opinions and can it be disabled?
ramltd01
Virginia
I've had my '23 limited for a short while now, and find the on/off feature to be a great benefit in traffic. However, I've found it to be a hindrance in parking situations, where I'm pulling into a spot. Guess I'm just on the cusp of stopped/rolling and the engine cuts - but etorque kicks in when I lift the brake a hair. Are there a tuning/configuration options (AlfaOBD?) that allow a user to set time delay for on/off??
Thanks
KeithP
Hemi 5.7 VVT
Thanks
Had my 22 Laramie since October. Tried my darnedest to get used to the eTorque and appreciate its so called benefits. I have given up. I just turn the stupid thing off now every time I start the truck.
Administrator
There is a module you can add so you don't have to manually turn the Engine Start/Stop off every time you start the vehicle:
The eTorque functions can't be turned off with the switch, module or with AlfaOBD.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
And that was the best $79 I've spent on any truck LOL
Lon Saeger
Elk River, Minnesota
Can the engine braking be turned off on the e torque? When you touch the brake the trans downshifts. I want to coast to a stop sign. Pushing the disable button will not shut off the engine breaking.
RBJRBJ
Va
Hemi 5.7L V8 MDS VVT eTorque Engine
The start/stop function can be turned off. And, it stays off until you turn engine off; upon restart simply press button on turn it off.
star_deceiver
Airdrie, Alberta
3.6 Pentastar
Reach down to the shift knob and put into neutral. Coast to your hearts content.
Lon Saeger
There is constant downshifting or engine breaking with the E torque. I find I am putting it into neutral every time I touch the break pedal, them the truck will coast. Turning the start stop off does not change the downshifting. Tow mode is off. Dealer says there is no fix for this.
Orca
