E vs D
risnalex
4.7 Flex
I have a 2010 Trx 2wd single cab. I do not go off roading. Just simply drive to school and back! Right now, I have 275/70/17 load range E that came on the truck. I'm looking to get some 315/70/17s or 35x12.5.. My problem is that most tires in those sizes are load range D.. Can somebody explain if it matters if I get load range D?
I do not haul of tow anything..
Also, any opinions on retreads?
Hemi395
Cape Cod MA
If you don't tow anything or carry heavy loads, load range D is more than enough for what you will be doing.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
You only really need E rated tires once you get into the payload ranges that are in 3/4 and 1 ton models. Most 1/2 tons are using either passenger rated or D range tires. Since you haul very little, a D range tire will do you fine.
As to retreads, most will tell you to not even deal with it but 99% of the issue with retreads is know who the actual company is that does it and what their reputation is. I know a local utility company that uses nothing but retreads with very little problems but they are setup to recover themselves if they do have a premature failure. Have to weigh the pro's and con's for yourself.
MADDOG
Living in a Firepit
E load range tires are used when you tow loads a lot. If you aren't towing a trailer or really loading up the bed close to max payload all the time, you won't need them. D range tires are more than sufficient for your use.
joshhhh
