ECM wiring harness replacement
mrryan76
Los Angeles
Hello, not sure if I am posting this in correct location...someone please move if not...
2016 Ram 1500 5.7
Have taken my ecm board out one too many times, and the connectors have broken. Not only the outside part with the red locking lever, but the actual connector with the green and blue tabs have split open on the sides. I ordered new connectors from Digikey, but cannot find any shop that will do the replacement. Attached is a picture of the parts I need to replace.
I understand there are at least 100 little wires and pins that need to be swapped, but I am out of ideas for where to look for help. Cant find anything specific on youtube and nothing in any forum.
Hopefully someone can point me in the right direction!
Thanks
Brian2081
Weatland Michigan
Its not that hard, I replaced the 52 pin connector behind the left front wheel liner. Use a small eye glass standard screw driver to release the lock holding the pin inside the connector.
Do one wire at a time, take it out of old connector and install in new one. Just make sure you put it in the correct position.
Jmshoey
Mount Forest Canada
whats product number is that? i need to replace 1 of mine as well. ive found the red handle section but i need the base
Carbary
