Ecodiesel Issues
Crescent1101
Tampa, FL
3.0L ECODIESEL
So I my truck broke down the other day so I had it towed to the dealer. Went into limp mode so I turned it off and it didn't start. It has been sitting at the dealer for two weeks and they just now started to look at it. So they finally got to me saying they can't figure out whats wrong with it. They asked if it was tuned and I said yes. I told them not to return it to stock and I will come do it for them so they can reflash it and I don't get locked out. They did it anyway and now they said my no start issue is my PCM. Worse news is they don't know when the PCM is going to be back in stock.
Started to wonder if my tune was what caused my issue with the PCM. I've only had the truck tuned for 3-4 weeks. I have the DPF and SCR delete with a ECU and transmission tune. Sorry if this post seems like a cluster. Also they told me the PCM was $2k
Richmond2000
I would reach out to the tuner and "read them in" as MOST dealers BLAME the tuner and "insist" you return the truck to FACTORY stock then they will continue at that state
can you "undelete" the truck or are your parts "punched"
I would personally have the truck TOWED to the tuner / deleter and have them undelete it and only then try repairing it at the dealer
OR better yet find a local diesel truck shop and have them LOOK at it
green diesel engineering also sells / used to sell "tuned" ecm's on an exchange case - assuming the "PCM" is the engine control module
Hammer757
Virginia Beach, VA
I have a 2016 Jeep GC with the Eco diesel. I have put in two PCMs and still have problems even starting it. They have ordered some more parts, but I'm being told a lot of the diesel parts are on back-order. Was told they changed how they grounded on the PCM and it is causing a lot of issues. At this point I just it to work long enough to go trade it in.
Crescent1101
Crescent1101
Tampa, FL
3.0L ECODIESEL
Well today they said it was the whole fuel system. Quoted me 8k to fix. No way I can afford this right now. I honestly don't know what to do.
Crescent1101
Crescent1101
Tampa, FL
3.0L ECODIESEL
Just read the warranty from FCA and says my Fuel system is covered. Problem is my truck is at the dealer right now with it deleted.
mtnrider
Georgia
You basically have no warranty at this point because you deleted though. I'm sure they have a record of it now as well so not going back. That's the down side of deleting and what has kept me from doing it on my cummins.
Do you know what codes it threw when it went into limp mode? A lot of times they are emissions related but since you are deleted that might well point to an issue with the tune?
What are they saying is wrong with the fuel system?
Wish you luck
Crescent1101
Crescent1101
Tampa, FL
3.0L ECODIESEL
They are saying that it just needs replaced. I'm hoping its not reported as being deleted. I'm going to get it from the dealer tomorrow and call to see about my warranty. Going to try to find someone who has DPF that I can borrow. Anybody know of a good place besides dodge to take it?
Shawn226
Mercer County, Pennsylvania
3.0L EcoDiesel
so the major downfalls with this that I foresee being issues for you are that;
1) they already know it’s deleted and I’d be willing to bet they have noted it in the system and flagged your vin. I hope for you that they let it slide, but I wouldn’t hold my breath on that.
2) borrowing a dpf filter is kinda hindsight now, that would’ve been my first priority before getting it to the dealership.
3) i would definitely get a second opinion on a private party diesel mechanic on fixing it if your warranty is shot. You might have better luck and it might be cheaper.
This is absolutely all speculation on my part so don’t take it with any weight. Hope things work out for you, however I would definitely call the company you got your tune from, see if they have any explanation or experience with this happening to other customers
Hammer757
Virginia Beach, VA
Did you get the recall work done on the diesel? It extends your warranty coverage and they send you a check for a little of $3k. Granted I'm not sure how your delete will play into the warranty.
Shawn226
3.0L EcoDiesel
He already got the check and used that to do the deed if I recall correctly from previous posts
FCAEMPLOYEE
Illinois
Dealers cant be trusted. They are there to make money, not because they care about you or your vehicle.
Crescent1101
Crescent1101
Tampa, FL
3.0L ECODIESEL
Yup used Dodge money to do delete since my truck drove like crap. My dumb butt trashed the stock stuff.
Crescent1101
Crescent1101
Tampa, FL
3.0L ECODIESEL
Got a 2nd opinion from a well known diesel shop and they said unless the HPFP exploded then a a light flush should fix it. Even it if it did grenade its shouldn't be $8k. The dodge dealer told me told me today they weren't sure and had to contact chrylser for a 2nd opinion. Think Im going to trade this in on a Ford when this is all said and done. 3.5L Ecoboost!!!!!!!!!! Selling one of my racebikes to pay for this. Let me know if you want a 2013 Semi Built ZX10r.
Shawn226
3.0L EcoDiesel
Do some research on the ecoboosts too though, some people I know say they’d never buy one again.
