bigtigga84
- Dec 19, 2010
- 3,459
- 35
- Location
- dela....where?
- 2006
- Hemi 5.7
so i pulled the bottles, shroud and fan out of the truck saturday so i could clean the radiator fins. (been having some temp issues). how im thinking about wiring a three way switch so that i can go between the high and low speeds of the fan. my concern is burning the switch up on the high side of the fan. i hear that the taurus fans pull crazy amps. i've also been reading that the major pull is to get the fan going. i would be starting on the low side and then switch over if need be. would a three way toggle work for that? im going to use 10 awg wire to run everything, i think that will be heavy enough. just can't get the switch figured out. and i really don't want a switch that is down on, middle off, up on. id rather have d-off m-on u-on. does anyone know if there is a switch like this?
