Egts high and low boost
Jacob19
arizona
So I have a 2007 dodge 5.9 I bought the truck and it had
Twin cp3
I believe 200 horse injectors
And a couple other small things but I put on a fass, Evilfab second gen swap with a s464. I got custom tunes for it as well, now I know it’s not going to spool up the second I touch the throttle but it seems like it takes way longer than it should and at most cruising speeds it not building any boost or very little. As for my egts they are about 850-900 just cruising about 55 and the second I get on the throttle I’ll be over 1200and climbing. So I’m just not sure if I need a different setup or maybe this is normal
MADDOG
Living in a Firepit
6.4L HEMI
How much coal you rolling when you increase throttle pressure?
Jacob19
Jacob19
arizona
A decent amount, it pretty much hazing all the time. Idling, in gear and just cruising
