ELECTRIC FAN INSTALL
Buckeye ,Az
i'm looking to remove the stock fan off my 2017 1500. And install an Electric cooling Fan.
Anybody know where i can get a good quality electric fan setup ?
CarKnockerJim
Martin TN
I will be doing the e-fan install here in the next few weeks....my buddy at local pull a part said a rear ended and rolled 16 with a V6 just came in...where should I tap in for factory wiring or should I just do an aftermarket switch and wiring?
Wahrsuul
Central S.C.
Hm, with a '17, I'm not positive, there's a thread in here somewhere about it. On the earlier models, we remove the AC fan and use that connection. If you're running a 180 thermostat, it's recommended to have a tuner to set the temp at which the fan comes on.
