Engine change
Mitten Diver
Jackson, Michigan
2011 Sport Crew Cab
I am going to replace the engine and trans with 170000 on it. I want to replace my MDS engine with a VVT engine. Do I need to replace my computer for this option?
Unless your truck is older then 2008,you already have a 5.7 equipped with both VVT (variable valve timing) and MDS (multi-displacement system). They are 2 totally differant systems.VVT advances and ******* the camshaft in relation to engine rpm,while MDS basically shuts down cylinders by collasping the lifters.That's a basic laymans explanation,but if you're doing an engine swap on a 1500 newer then 08 ,your original engine has both systems.
jws123
nj
Howcome you are replacing engine and trans? I wouldnt do it unless there is a issue I have 230k on my orig engine and tranny lol 170k is nothing for these trucks.
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Good question. I'm over 318,000 on mine.
joshhhh
