Engine change
Mitten Diver
Jackson, Michigan
2011 Sport Crew Cab
I am going to replace the engine and trans with 170000 on it. I want to replace my MDS engine with a VVT engine. Do I need to replace my computer for this option?
Unless your truck is older then 2008,you already have a 5.7 equipped with both VVT (variable valve timing) and MDS (multi-displacement system). They are 2 totally differant systems.VVT advances and ******* the camshaft in relation to engine rpm,while MDS basically shuts down cylinders by collasping the lifters.That's a basic laymans explanation,but if you're doing an engine swap on a 1500 newer then 08 ,your original engine has both systems.
jws123
nj
Howcome you are replacing engine and trans? I wouldnt do it unless there is a issue I have 230k on my orig engine and tranny lol 170k is nothing for these trucks.
MOPAR78
2014 Ram 1500 4x4
6.2 Demon
Good question. I'm over 318,000 on mine.
Rambo 17
