Engine running hot
Terrance
Scottsdale Arizona
2008 &1977
6.7 ******'s & 318 W100
When I'm at a stand still my truck starts to run hot between half and red unless I'm going highway speeds. I'm missing half of my fan shroud but I don't think that would be a big deal. I do have a 3" body lift so the radiator sits 3" higher from the motor. Would that be the problem or is there something I could do to get the heat out?
NYCruiser
Yonkers, NY
Fan shroud is definitely a big deal. Over heating at idle is a classic missing shroud symptom. I would start there before you go crazy.
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
You need to either replace the broken fan shroud, or replace the shroud, fan, and fan clutch with an electric fan kit.
