Engine swap - 2000 5.9 into a a 1997 - possible?
Lethalweapon100
NY
V8 5.9 Magnum
Hello erryone. Been a while since I been on RF. Not much is new. Dumping money into projects. But anyway.
My 1997 Ram 2500 5.9 V8 just rolled over 225K on the clock yesterday. That motor is old and tired as hell. It burns so much oil its ridiculous, even after the plenum repair. It cant hold oil pressure for sh*t, so im thinking its on its way out and I sure dont want to throw any more parts at it only to have it die in a week.
However, I did find a 2000 Ram 2500 V8 that somebody is parting out. 76K on the motor. I asked how much, and if I can hear it run. Well he has yet to respond. But is it possible to swap a 2000 motor into a 1997?
Thanx.
Sent from my SM-G920P using Tapatalk
dapepper9
Iowa/Nebraska Border
5.9L V8
Very. Use your harness and swap your intake manifold, fuel rail, and injectors all over as a unit
L
Lethalweapon100
NY
V8 5.9 Magnum
Sweet! This makes me very happy, qs I just did my plenum not 2 months ago before i decided I just wanted to swap motors.
He says he just pulled it out of the truck. I told him let me see it running, and ill take it...
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I would reseal the new engine, put in a timing chain and water pump, plugs, wires, cap and rotor all for sure.
Might as well because you'll get no better time
Mohpar
Magnum 5.9
Throw some aluminum valve covers on it :rolleyes:
L
Lethalweapon100
NY
V8 5.9 Magnum
Ive been thinking. Let me let yall in on my plan.
Still unsure if motor runs or has issues. If none or minor, he wants $350. Will buy all new gaskets/seals/etc and pay guy at my CJDR Dealership $100 to blow through it with me and take a look.
Not a bad idea, yes?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I'd say yes do it, but if you cannot hear the thing run, I wouldn't pay more than I can safely throw away.
L
Lethalweapon100
NY
V8 5.9 Magnum
Thats my issue. He says its out.
Whats it take to make one of these motors run out of the truck?
L
Lethalweapon100
NY
V8 5.9 Magnum
What other years will fit this truck for a motor?
jared.hammel
Knob Noster, MO
Magnum 5.9L
I know this is an older thread, but can I swap from a 2500 to a 1500 same year? Both 4x4 or only one 4x4?
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
As long as everything is original and the truck was originally equipped with a V8, I'm under the impression that any 5.2/5.9 Magnum engine will directly swap in.
Hell, I'm pretty sure the old LA engines will bolt right up to a 46re transmission, though there are numerous reasons why you better be 110% that you want to go carbureted to make it worth the trouble...
topherztoyz
