Ever use the + & - Gear Buttons on steering wheel?
af2018
Pennsylvania
When I press them i see 1- 8 next to the 'D' on the display. What is the purpose of this? Am I changing into 8 different gears??
chrisbh17
the 1 is the gear you are currently in, the 8 is the maximum gear the trans will shift to.
Once you see the 8, you can use the - button to lower the 8 to whatever gear you want the trans to max out at.
Nice feature, wish there was a way to define what gear the truck takes off in as well, but not a huge issue.
af2018
af2018
Pennsylvania
i don't get it. whats the point or benefit?
chrisbh17
Helps with towing for sure (even though Tow/Haul mode is supposed to as well)
Certain spots where I drive the truck wants to be in a high gear but with twists and turns it just ends up bogging down, so I make sure it will only go up to 6 or 7 in those areas
Same deal for when I have a brief run on a highway, only 1/2 mile or so, no sense letting it get into 8th
AND once you use the +/- buttons, it automatically disables MDS (even if you let it go 1 through 8, it still wont engage MDS)
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
I use the manual shift religiously when towing along with being in tow/haul mode.
My 68RFE seems to continuously hunt\search for the correct gear if left in regular drive with tow/haul mode. (When towing over 10K lbs)
The manual shift buttons on my steering wheel creates the manual transmission effect. Gives me more control over the transmission shift points.
Which is a huge plus when towing a heavy load up & down steep hills or mountains.
turkeybird56
Central Texas
They also allow you shut off the MDS so your 8 cylinder truck runs on all 8 cylinders instead of 4.
DITTO. I use them to turn off in town or very hilly roads. Otherwise I just leave trans as running.
6.7CumminsDrvr
The Dude abides………
Georgia
I use it on this nice little road I frequent, lots of twists and turns, Hemi sounds awesome winding out and is so punchy coming out of the corners in 3rd or 4th gear!
Hawkman
South Carolina
i use mine normally when traversing hilly terrain and I dont want my tranny to keep up and down shifting. And to get rid of the drone from the Carven Progressive muffler when the MDS kicks in on the hwy.
Sled Freak
Perth County Ont
I'm starting to use my more since I put a borla xs muffler on my truck. When the mds kicks in it changes the exhaust tone and I don't care for the sound. I also find when driving in town the truck is in to high of a gear and lugs so if feels doggy. I usually shift it into 5/6 when driving under 65kms (40mph) plus the rpms go up and it sounds way better.
huntergreen
Marine Corps Navy Badge
I would probably use the ERS more if the buttons were bigger.
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I use it when towing to limit the highest gear. Even on "flat" freeways, any little hill will cause it to shift to 7th. So I usually limit it to 7th gear on freeways. On other roads, especially hilly, I will limit it to 6th or even 5th.
One thing I like when in this mode... it shows the gear the transmission is in. I wish it always did that, even when not limiting the highest gear.
gixxer
SK Canada
4.7L
I use it every day. Great for towing or off -roading
Mike Flea
US ARMY VETERAN
Streamwood, IL
Always wondered about this myself, my 2010 has the up/down switch on the shift lever. Thanks for the replies :waytogo:
Fryekenn
