Exhaust Tips
twooldfarmers
SK and AZ
2014 Laramie Crew 4x4
OEM tips to 5's
I did this and there is no difference in the audio whatsoever as far as I can determine
not sure that I would expect any difference with a non baffled or internally serrated tip anyway
my SSR came with a double wall 3" inch tip that was serrated in the same way a Cherry Bomb is with a glass mat and when I put the straight 5's on there was no difference that I could truly tell either.
I think you would need some pretty sophisticated sound measuring equipment to pick up on any changes that may have occurred
T
twelver
Thanks twooldfarmers!! Those tips look awesome!!
Big Boi
S. Fla
See.. it's that simple to help out a fellow forum member.
BlownGP
Houston/Baton Rouge
x2
Going from a 3" to 5" tip will not make a notable difference in sound. Especially with them not being resonated tips.
