Extended Travel CV Axles
Victor Brill
Kansas City
Good Afternoon,
Have a 2011 Ram 1500 leveled with Bilstein's. Have heard extended travel CVs mentioned before when leveling and should have already looked into putting those on as I have chewed through a couple sets of CV Axles. Have also heard people mention heavy duty axles. Looking to purchase some new axles but wanting to make sure I am getting the correct ones. Rockauto list the trakmotive ones as a fit for my vehicle but want to make sure those are correct for only a leveled truck and not meant for a higher lift? Let me know your thoughts.
Trakmotive Extended Travel
Cardone Heavy Duty
Any help is appreciated.
DILLIGAF
Canada
Trackmotive CVs are dog**** trash, research them !
V
Victor Brill
Kansas City
I have seen people say that but I am not trying to spend too much money honestly. My truck is a 2011 with 180K, and rusting so not really worth a ton. Just need something affordable to get by and not pop every time I back up/turn or wear my tires out quickly. Are the heavy duty Cardones a better option? Will they have the same angle/length issue I am already having? Any other affordable options?
osprey ram
09 1500 4x4
4.7 lit.
I am also looking. Detroit axle seems to be the only one not made in china. Do not heard much about em.
V
Victor Brill
Kansas City
All the info is literally 3 thread down if you took time to look. https://www.ramforum.com/threads/extended-cvs-when-using-a-diff-drop.206975/
Maybe I did take the time to look at that thread and what info is there that tells me everything?
That thread is a guy with a 4 inch RC lift and a dropped diff and then post about a Jeep. while we are having similar issues with the popping, I am only leveled with Bilsteins and wondering if Extended CV axles or Cardone Heavy Duty axles will help my situation at all or if anyone has used those and had success. My CV axles need to be replaced and I don't plan on replacing them with stock ones again even if the other options aren't the greatest either. If I replace those and am still having issues then I will go from there.
There is a post about a spacer that will fit over a axle spins but that is the first I have ever heard of that.
One post about the washer being installed wrong on the Bilsteins could cause a popping.
Then there are post saying it could be a stabilizer link or ball joint or any other front end part which doesn't necessarily help. Then one last post about your track bar and drag link being parallel.
Outside of hearing about that spacer for the first time, I am not sure which part of that info assist me when discussing whether anyone has had success with extended CV Axels or if Cardone heavy duty axles would be a better choice(have read threads about those).
ginandtonic
Canada
Trakmotive extended ones are going on mine tomorrow so I'll let you know how it goes! As far as long term durability, probably depends solely on your use of your truck.. I'm 99% on road so don't anticipate flexing them much.. if I used my truck more offroad then coughing up a bit more $$ for something better might have made more sense.
ginandtonic
Canada
The new axles didn't fix my clunk, but I'm glad it can safely go through full articulation without one popping off now. I have a Rough Country 4" lift and the more I learn about it the more I realize how much it messes up the front diff/axle geometry, even with it being dropped. As far as aftermarket CV's go, I've also learned that there really aren't any great options out there. It seems the mopar ones last the longest, and aside from Cardone, everyone else just repackages Trakmotives (napa, etc) and sells them as their own, but ultimately theyre all the same.
Bam930878
Illinois
I was about to ask a question along the same lines im getting ready to install a rough country 3” lift level new corrected uca lifted struts shocks and spacers in rear but i have come to find my ch axle boots are both blown out and curious if it would be beneficial to upgrade to direct replacement higher articulation cv shafts
ram1500rsm
Trabuco Canyon, CA
The entire aftermarket cv axels for our trucks are a POS, Crapdone, Moog, Detroit axels, etc etc etc. you'll be changing boots or CVS at every oil change. if you want a cv axel that will go past 100k miles laughing nothing can't beat stock. Problem is the stockers are very expensive. Pick your poison accordingly. There is zero need for extended travel cvs in this application unless you go with silly spacers at the top of your struts. Maxed out 5100's won't overextend your CVs.
