Factory 4 flat connector. No right signal.
Apiazza
Westminster, MD
I hooked up my trailer to find no right turn signal. I assumed it was the trailer wiring so checked resistance throughout to find all was good. Put the meter on the 4 flat connector and had alternating current on left signal but absolutely nothing on the right. Has anyone had these connectors go bad? All seems in good condition
Sent from my SM-G965U using Tapatalk
Deepc6
Long Island
Hemi 5.7 Etorque
Did you turn on the tow/haul mode?
I had similar issues until I turned it on
Apiazza
Apiazza
Westminster, MD
Why would that be? I can check it in the morning. I remember it working in the past.
Administrator
Check for power in the 7 pin jack(the 4 and 7 pin jacks are feed from the same wiring. Also there are fuses for the trailer lighting/brake under the hood.
The Tow/Haul does not have to be on for the trailer lights or even the brake controller to work. If that is the case, there is a problem with your truck.
David H
USA RET
Minneapolis
Fuse # F81
Mine were some kind of M case fuse. Hard to find. Had to order it online.
Apiazza
Apiazza
Westminster, MD
I'll check the fuse shortly. I would have thought it would 1 fuse for all trailer connectors. So that's not the case?
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Every trailer lighting problem I've ever had was ground related. Good luck in your search for a solution.
Jay
Administrator
There is 6
F11
F28
F29
F30
F53
F81
Reactions: kad
Apiazza
Apiazza
Westminster, MD
Fuse was blown. Thanks for the help. I cant believe I didn't think to check it.
