jrenton2185
Reading through the forum, seems like many people have issues with turn signal hyper flash. Most have done the swap to LED's however. I have a 2017 Laramie with stock LED. My r rear turn signal keeps throwing a message and the mirror light will hyper flash. Last night I went out and turned r signal on to see what's up. Looks like 2-3 of the LED's on my right rear turn signal are indeed not blinking with turn signal on. It looks as though they are on constant lighting however (driving/parking) is the park/driving light seperate from turn signal light on LEDs? Also, is there a way to trick the truck into thinking all lights are indeed on and working? Only solution I have found is buy a new housing, which at a couple hundred $$ is a bit much for 2 tiny lights out. Cant even tell unless you are really looking for it. Just annoying to have the constant message error and hyper speed clicking in the cab. Thanks guys.
Sent from my SM-G965U using Tapatalk
