Factory tailgate damper
Kfield
Johnson City
Is there a way to get the factory tailgate damper? I know I can get a Dee-Zee, but would rather have the factory if possible.
K
Kfield
Johnson City
Adam vera
SC
I believe this is installed behind driver side tail lamp out of sight. You can also order power tailgate release to go with this kit. Ill try to upload the install instructions tomorrow.
K
Kfield
Johnson City
Here it is
Thank you! That’s what I want.
Now will it allow for power release if I get the sales code added, or is that a different module?
Adam vera
SC
Not sure on this.
Adam vera
SC
From install sheet it looks like the keyfob with release button and reprogram, but I could be wrong
Yeah looking at it again you would need to buy both accessories, in order to achieve what you're looking for.
K
Kfield
Johnson City
That would not be worth the fob and dealer flash cost
K
Kfield
Johnson City
I just spent a good while with the parts dept. Bottom line just need a keyfob and program for tailgate release.
Then I looked at the remote start and the kit comes with 2 new 5 button key fobs. Mopar could not say if those keyfob had the tailgate release button on it or not. If I can confirm this I will go OE with the remote start.
Mopar has no clue about the accessory kits for these trucks. They at first said my damper should have came with new fobs. Then the parts person pointed out it had 2 part numbers and the Mopar person couldn’t even find item for the fob part number. It was a joke.
The damper installed in under 5 min and works great. That included getting tools together and put away
