Fahren Led head lights
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
has anyone installed the Fahren H11 and 2005 head lights ? if so did you have to clock them or adjust your head lamps after?
or have any issues with them?
Gregdad
Fort St. John BC, Canada
You need to clock them to the 9&3 position to get the best output. They give you a small Allen key to help.
Top pic is low beam, bottom is highbeam so you know what to expect with Fahren bulbs.
PolarisCobra
Mendon, MA
SST SO
As said above, clocking is required, and easy to do. I have them in low beam and fogs, and I like them very much. They made a big difference for me.
Jim BB
Jim BB
Hamilton ,ON
That's great Thank you very much !
PCT
2019 2500 6.4
Northern California
are they quality? i have been bouncing the thought in my head, cheap amazon brand LED or expensive name brand LED...
Gregdad
I had Fahren bulbs in my 19 with quad reflectors for two years and was totally happy.
I put them in my new Warlock also and they’re great.
A lot of guys use them. No need for extra resistors either.
I personally do recommend yhem
Phillyrube
Flatistan
I have them. Clocking is easy. Not impressed with output tho. Mine Also blink, not flicker. Set the computer for led but no change. To be fair, i am running them through oem housings, 2008 ram
Phillyrube
Flatistan
Well, flickering is now a moot point, one of the Fahrens just up and died. So now I gotta try something else.
Jim BB
Jim BB
Hamilton ,ON
yes they work very well! very happy with them
Jim BB
Jim BB
Hamilton ,ON
Update on Fahren LED lights put them in my 2019 1500 classic with quad reflector light No flicker no issues at all !
clocked them as per instructions no problems !
i put high and low beams in very bright very happy with them would recommend them !
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
I had them in my '19 Classic for a couple of years and I loved them. No issues at all. I'll probably put them in this truck to.
Jim BB
Jim BB
Hamilton ,ON
i am slowly working on changing all my lights to LED just changed interior lights to LED and lic plate lights as well so that just leaves rear brake and signals , reverse lights and front marker- signal lights as well as fog lights the fog light i haven't changed yet because Fahren LED's like most have fans on back and the fog light don't have a cover or shield over them so fan will be exposed to weather Ie snow slush rain ect! so trying to find a good quality LED bulb that won't brake the bank at a reasonable cost and is dependable and works well! any suggestions or ideas !?
Thank you Lady's and Gentlemen in advance !
CanuckRam1313
Ontario Canada
2023 Warlock
I replaced with a full set of Vivid Lumen Industries Velocity LED's in the highs, lows and fogs on my 19' Ram and have had them for two years now with zero issues. They all have fans on them and no issues with the fogs through Canadian winters.
I also replaced all other exterior bulbs as well at the same time. What a great improvement going to LED's is. The light output is so much better!
Nice with with Vivid Lumen is that they also provide a lifetime replacement warranty on all their Velocity line LED's, and their customer service is fantastic as well. You call, you get to speak to a real person..lol
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
I too use them and liked them so much done both high and low beam and then replaced my hid's in my 05 lesabre with them I also replaced high beams on car as well love them no more delayed on
dalewalt
Air Force
Pittsburgh
3.6L V6
Hi Gregdad, question for you.
My Warlock is a '22; Amazon said that these: Fahren won't fit. Are they the ones you used? Any problems getting them to work, flicker, etc?
Thanks for any help
Gregdad
Thanks for any help
I’ve got a 21 Warlock and have 9005 for both low and high beams. I haven’t had any flickering issues at all in the year these bulbs have been in my truck. Just have to clock them to 9&3 position for the best output.
northvibe
Minnesota
I just installed the Fahren 9005 high and H11 low beams. Made sure to clock them 9/3 which some of the allen's didn't fit right but found one that did luckily. I have not adjusted the reflector in my quad housing from factory... curious how bad they will blind on coming.
alphaprojects
