Fahren LED's... love em.
Gregdad
Fort St. John BC, Canada
I just ordered a pair for my 2019 Classic low beams.
The high beams seem to be adequate, but do these make a much bigger difference in the high beams, or really just an improvement with the low beams?
Trust us and get the highbeams done too. You’ll be extremely happy.C3B9FABB-F486-470E-BF5B-5A15C86C7A3E.jpegI rarely use my 42” lightbar due to the Fahren highs being so bright.
bfill_rebel
For my 2016 ram Rebel with projectors it appears 9005 is the bulb for hi beam. Can those who are knowledgeable confirm. Thanks
Blstrick55
Everywhere
Tried to find them in H7 for my Alpharex lights but doesn’t look like they come in that size.
Got 1
Des Plaines,IL
5.7l v8
Yes, 9005 for low
Yes, 9005 for low/high beams in projector headlights. For high beam you need something smaller than usual due to limited space. I've just bought these from amazon and they fit and work great:
https://www.amazon.com/Headlight-SEALIGHT-Design-Upgraded-Warranty/dp/B07HCZ4VCH/ref=sr_1_10_mod_primary_lightning_deal?dchild=1&keywords=sealight+9005&qid=1616725200&s=automotive&sbo=Tc8eqSFhUl4VwMzbE4fw/w==&smid=A298MPJAFJ2R5R&sr=1-10
bfill_rebel
So after the who debacle figuring out new headlights to choose, I just opted to go with Fahren LED's (and another brand fog lights). Holy cow. Everything bolted in nice and easy, plug n play. Everything fit nicely in the dust caps. These things are BRIGHT. Very pleased so far. Thanks for all the info throughout the forum.
View attachment 240888 Lowbeams
View attachment 240889 Low w/ fogs
View attachment 240890 Fogs only (parking lights)
View attachment 240891 Highs/Lows
View attachment 240892 The whole shebang
Just to verify; you used these in your high beams as well and got it all to fit under dust cover?
ClassicJoe
NC
Trust us and get the highbeams done too. You’ll be extremely happy.View attachment 242204I rarely use my 42” lightbar due to the Fahren highs being so bright.
My low beams do not look near as good as yours... It is just not as crisp of a pattern. I have them both turned to 9 and 3. Yours seem to be possibly aimed a little higher than mine.
Gregdad
I noticed my drivers side was down a bit from factory so I raised it to match the passenger side.20CDF9C5-7A6A-467E-B486-180E76B2CB03.jpeg
Hammer22801
Louisiana
I have a 2019 and I used fahren for my highs and lows. They fit under the dust cap and are true plug and play. Spent about $70.
got my dual yellow/white fog LEDs from super bright lights for about $60
If you want LEDs I suggest fahren
ClassicJoe
NC
I just installed the high beams... I am not impressed with the installation aspect. The first bulb just needed an adjustment to get it aligned properly (I am assuming they should also be 9&3?), but the second was a whole other ballgame... I tried to adjust it and the little lock screw was stripped out. What I ended up having to do was shave down two of the flaps that go in and turn to hold the bulb in. That was the only way I could get them to fit to be able to turn it the correct way. I was also not able to turn the bulb all of the way in due to it not being aligned properly if I did.
Time will tell if they are bright enough to be worth it tonight, but not impressed with the install...
Also, my pattern still does not look as good as Gregdad's...
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Anybody notice a flicker issue and have a fix when running the Fahren's as drl's ? I have no issues other than that and love them.
1500ram12
5.9L Cummins
Have you adjusted drl voltage?
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
@1500ram12 I went all the way up to 9.8 V. It didn't seem to change anything and the packing literature with the Fahren's said they were sensitive to lower voltages running them as Drl's.
1500ram12
5.9L Cummins
You'll probably have to go to 12v minimum
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I'll try it at 12v, I was really only concerned with the longevity. I really like them and they work quite well. Thanks
ClassicJoe
NC
WOW!!! The high beams are bright as all get out! Definitely worth the trouble with install.
RamCares
n/a
n/a
Hello @likes2build,
We understand if you wish to continue troubleshooting in this thread, but if you would like additional support or assistance regarding your flickering concern please feel free to send our team a private message!
Hannah
Ram Cares
ChloeBrooks
