Fahren LED's... love em.
BLUKTY2
Anchorage, AK
Ok, cool. So two sets for the hi and low, right? What did you get for the fogs?
You are correct- two sets. I haven't settled on a fog light replacement yet; I have looked around a bit but nothing really jumps out at me. I have the horizontal for lights, #9145. I will go with yellow bulbs when I do decide on something.
Hendricks
North Carolina
I have a case of too much info here. I have a 2016 express with the quad headlights. Anybody know which bulbs I need for high, low and fog lights? Help would be greatly appreciated
Thanks
Robert
19johnnymac75
5.9L
I installed the Fahren terminators in my low beam projectors last week. This morning when I remote started the truck, I had a notification on the dash that said low beam is out. Neither of them worked this morning after great performance since install.
2016 Ram 1500 Sport w/ projectors
2016Bighorny
Wisconsin
Thanks
Robert
Yes, you need 9005 for highs, h11 for lows, and 9006 for fogs. I just installed all new LED bulbs from Danny at Underground Lighting. Very impressed with the whole setup!! No "bulb out" messages, no flicker, no issues whatsoever!! I installed fogs, highs, and lows about 2 weeks ago. Beam pattern is EXCELLENT!! Easy to "clock" too!! Oh, and they are RIDICULOUSLY BRIGHT!!!
Hendricks
North Carolina
Double checking the 9006 comes up as a headlight bulb. Is that correct for the driving lights?
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
My 2011 5.7 takes H11 Lows, 9005, His, and either 9005 or 9006 for fogs…. Weird. The Farhens LED bulbs are great. I bought a couple sets off Amazon a few years back, however now I’m running Adrenaline Offroad’s RGB-W headlights. No complaints so far! I have all
Their lighting products.
Hendricks
North Carolina
2 more quick questions. When clocking to 9 and 3 does it matter which bulb is which way? EG should 9 and 3 be inboard or outboard? Also is there anybody in the Raleigh NC area with AlphaObd that might be able to change my driving lights so they stay on with the high beams?
Thank
Robert
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
If you bought the right led bulbs there will be led chips on two sides only not all the way around. After installation, properly clocked, those chips will be on the side at the 3 and 9 positions both passenger and drivers side.
jeanbacan
Alberta, CA
V8
Im planning to change my halogen lights to these due price. It's a warlock 21. One thing Im thinking is, do we lose any kind of eletrical warranty from the factory? I think they give one year right? If so I'd need to stick with this crap for 6 more months. Even a camper headlight produces better visibility. Here in Canadian winter the oem has been terrible.
jeanbacan
Alberta, CA
V8
Thank you god bezos. Order this yesterday and got it today. Led 9005 for ram classic warlock 2021. Installed low beams in 1 hour. Has never done car work before. I see why some stores charge 2 hours to do it, but 3? Would cost me $300 in CAD just for the replacement which is crazy. The products like hid or leds would cost from $100 to $400 bucks. This for $50 you camt go wrong. I will test it for while and if everything is ok, I will swap the high beam as well, although I barely use it.
carlylelocke
Houston
Did everyone remove their grill to do this or is there a way to do it with the flap in the wheel well?
PolarisCobra
Mendon, MA
SST SO
I did mine through the wheel well flap. If you have trouble seeing something, you can often stick your phone in close and take a picture, to get a view of what is there.
carlylelocke
Houston
Good to know. I have replaced the headlight assemblies with blacked out ones, and I did not remove the grill, just wanted to be sure that that was still the best way to do it.
carlylelocke
Houston
Are you sure you went this way? There seems to be a dust cover that is smack in the way of doing this without removing the headlight from the truck.
PolarisCobra
Mendon, MA
SST SO
To replace the low beam bulbs, yes, I did it through the flap. There is a white part that slides up/down to unlock the assembly, so you can pull it forward. Did not take the grille off. As I remember, there are instructions for replacing the headlight bulb in the owners manual. That may help.
