favorite connectors to tap into speaker outputs
moregrip
Just wondering what everyone uses to tap the factory harness to pull speaker inputs for a LOC or 12v+ or remote power?
maybe like a good, better, best type thing......
BadHabit2Break
Houston, Tx
3.6L
I have the 8.4A and pulled the HU to add my NVX LOC. Ran power from the cig lighter in the console and the LOC provides me with a remote turn on. Amp only comes on when the key is in.
M
moregrip
thanks for the responses! very much appreciated
baum
savage, mn
2015 Laramie
and solder that?
i couldnt agree with this connection any more. personally when i did them unless it was a heavy gauge ignition wire i would not solder. when you solder you have to worry about cold solder joints and the solder not actually bonding if done incorrectly.
this is the easiest tool to do it with, but you can also do the same thing with with a basic strippers and a razor blade.
